Strong wind switches off the boiler
maulemon
maulemon Member Posts: 1
Hi,
The exhaust is fitted from a side of the house.  Every time when is a relatively strong wind - the gas boiler switches off just for a second or two. Typically it's not a big problem unless you are taking a shower - the the water gets colder. Sometimes when wind is really strong the period with cold water might even take 10-15s (and water gets really cold then)
Is there any device which can be fitted outside of the house to prevent wind from blowing into the exhaust?
Thanks,
mau.
  • Jim Pompetti
    Jim Pompetti Member Posts: 552
    Go over
    the instruction . You will most likely find that the vent is to long or your vented out the wrong side of the house
  • Steve_210
    Steve_210 Member Posts: 664
    vent
    can we see where vent terminates or can you describe
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    What is the make
    and model of the boiler? This will help in determining correct venting. Typically there is no device that can prevent high winds from affecting a vent other then relocation.
