Cast iron rads and knight
rebmech
Member Posts: 7
Owner has now changed his mind from running copper tube baseboards to cast iron rads. My instinct is telling me to separate the knight and the rads with a heat exchanger, but i cannot seem to find any recommendations from Lochinvar to do this.
Thoughts
Thoughts
consider
a good dirt separator and you should be fine. Not a Y strainer which can plug and reduce flow. A dirt separator removes smaller particles and does not reduce flow.Bob "hot rod" Rohr
Living the hydronic dream0
- 167 Indoor-Air Quality
