Cast iron rads and knight
rebmech
rebmech Member Posts: 7
Owner has now changed his mind from running copper tube baseboards to cast iron rads. My instinct is telling me to separate the knight and the rads with a heat exchanger, but i cannot seem to find any recommendations from Lochinvar to do this.
Thoughts
    hot_rod Member Posts: 26,604
    consider
    a good dirt separator and you should be fine. Not a Y strainer which can plug and reduce flow. A dirt separator removes smaller particles and does not reduce flow.
