grease buildup in drain
thanks, i'll give it a try--nbc
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    anyone had experience with some preventative procedures to alleviate grease build up in restaurant drains. i know that lye [sodium hydroxide] plus grease = soap, but does it work in drains?--nbc
  • mtfallsmikey
    mtfallsmikey Member Posts: 765
    Try this:
    Natural Enviro 1000 - Grease Trap Solution...
    www.naturalenviro.com
    This is a bacterial type product.Does a fairly good job.No lye.
    I used to use Chloroben PT. don't know if it is still available or not.
  • scrook_2
    scrook_2 Member Posts: 610
    Install...
    a grease trap and have it cleaned on regular intervals. Is a grease trap not a code requirement in your area for this application/use?
    Lye (sodium hydroxide) based crystal drain cleaners should be effective on grease deposits however.
  • an old wrench puller
    an old wrench puller Member Posts: 73
    I like this stuff
    http://www.zepcommercial.com/products.asp?category=11
    Any good supplyhouse will have a good non- acid cleaner. regular use is the key.
  • yeah, g traps in restaurants
    i thought they're national code
  • Rich Kontny_3
    Rich Kontny_3 Member Posts: 561
    Bio-Clean
    has environmentally safe products for both residential and commercial application. A time proven product line
  • mtfallsmikey
    Good to see you again, Mike!
    How's things at M & A?..I see some of your guys coming bck up the road in the afternoons.
    Jamie Hall Member Posts: 26,832
    if it isn't
    code in your area to have a grease trap on a commercial kitchen (e.g. restaurant, school, etc.) it should be. In any event, do install one -- at the very least on the dishwasher drain and any sinks used for cleaning or dishwashing.
    And Then Make Sure It Is Cleaned Out! Can't tell you how many grease traps I have inspected which were never cleaned out.
    You'll need a drain cleaner as the other guys have mentioned to get rid of the gook that's already there...
    Trust me: you'll have much better drains -- and the guys at the sewer plant will be very appreciative! Of course, if you have a septic tank, the guys who clean it will hate you, as they won't have to pump it so often!
