mystery steam device?
norfitz
Member Posts: 55
Can anyone identify this mystery steam device? I'm stumped.
Mystery
Looks a bit like a separator/receiver or trap?0 -
I've seen that...
somewhere... in one of Dan's catalogues in the library. Hoffman catalogue, maybe? Tried looking there?Br. Jamie, osb
It's an air trap
which was used as a dry return vent on a Vapor system. The vent opening on top usually had a vacuum check screwed into it.
That is a 0023 size (1\")
Warren Webster Vent Trap and did what Steamhead says it did. Looks like it has seen better days!
Steamhead
Why was a trap needed. Why not just install a checked vent ?There was an error rendering this rich post.
The air trap
also had a float in it, to keep water from escaping. But it didn't shut on temperature. It was assumed the radiator traps would keep steam out of the dry returns.
Thanks Steamhead
Thanks For the lesson.There was an error rendering this rich post.
thanks!
Steamhead you rock! Thanks very much for your help. Bruce0
- 167 Indoor-Air Quality
