steam heat
pat_36
Member Posts: 1
Anyone know the steam heat that also heats my hot water system well??
Say what?
I'm afraid I can't really figure out your question -- can you rephrase it?Br. Jamie, osb
anyonne know
I think the poster has a steam system with a tankless coil0 -
it sounds like you make hot water for domestic use off your steam boiler and your asking for the setting on the relay it should be 120-140 can be as high as 160 if its attached to seperate hw tank running off 4006 with differential at 200
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
