steam heat
pat_36
pat_36 Member Posts: 1
Anyone know the steam heat that also heats my hot water system well??
    Jamie Hall Member Posts: 26,838
    Say what?
    I'm afraid I can't really figure out your question -- can you rephrase it?
  • ed wallace
    ed wallace Member Posts: 1,612
    anyonne know
    I think the poster has a steam system with a tankless coil
  • Frank_62
    Frank_62 Member Posts: 16
    it sounds like you make hot water for domestic use off your steam boiler and your asking for the setting on the relay it should be 120-140 can be as high as 160 if its attached to seperate hw tank running off 4006 with differential at 20
