any tips on running a radiant loop off a steam boiler?
Bob Gagnon plumbing and heating
Member Posts: 1,373
If it is not being used for domestic hot water. They make coils with 3/4" tappings for this purpose. I did one that way and it worked great, no worries about sediment.
Thanks, Bob Gagnon
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=331&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Thanks, Bob Gagnon
any tips on running a radiant loop off a steam boiler?0 -
Definately use a plate exchanger with the circulator and exchanger protected by a wye strainer and bypassThere was an error rendering this rich post.
Add sediment faucets to steam in and condensate out ports on your heat exchanger, to allow flushing of mud out of the small galleries within the plate type heat exchangers.
Shell and tube type exchangers have less fouling problems but are larger in size and more expensive.
Good Luck0 -
- 167 Indoor-Air Quality
