any tips on running a radiant loop off a steam boiler?
If it is not being used for domestic hot water. They make coils with 3/4" tappings for this purpose. I did one that way and it worked great, no worries about sediment.
Thanks, Bob Gagnon
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=331&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • jrob
    jrob Member Posts: 1
  • Norm Harvey
    Norm Harvey Member Posts: 684
    Definately use a plate exchanger with the circulator and exchanger protected by a wye strainer and bypass
  • Canadasteam
    Canadasteam Member Posts: 13
    Add sediment faucets to steam in and condensate out ports on your heat exchanger, to allow flushing of mud out of the small galleries within the plate type heat exchangers.
    Shell and tube type exchangers have less fouling problems but are larger in size and more expensive.
    Good Luck
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    Yes.
    Go HERE
    It pays to wander off the Wall.
    Retired and loving it.
