W-M Ultra owners/installers, take note
brian p
If there is corrision on the out side, there will be corrision on the inside as well. I would take heat exchanger apart to clean boiler(should be done annualy) to be sure condensate is running through boiler properly!
Corrosion
I recently had an Ultra80/S2 go into lockout with a E29 error code [Blower/fan not at zero]
Upon inspection, the blower is directly under the air intake port, and suffered abnormal corrosion after 3 years
I live on the coast, less than a mile from the ocean and build up seems to be related to salty air/fog/rain
So far, cleaning the ground strap, has not let problem return as of yet
I wonder if the series 3 is designed the same way?0 -
other cause
Same thing can happen with cross-contamination by flue gas. A larger separation between intake and exhaust usually cures it.0 -
That Location
is less than ideal in very cold climates too. I have had them freeze solid from ingesting ice cold air through the vent holes in the top of the air horn. W/M suggested solution was to install a deflector shield to divert ice cold air away from the motor. Of course there is lots of room for that!!
Quality design!?!?0 -
Nope
Not the ground, error code/lockout came back, I noticed this time that 2 007 circs continute to run as well.
Reset and disconnect allow it to fire back up once blower stopped
Currently got it running at LF, so it will not cycle off, gong to be single digits this weekend
Anyone else experiance this lockout? /fix0 -
E29 onUtra 155
I had the same problem this month. It is about 3 years old. How can i run at LF? what does the LF mean?
I talked to a technican at W-M. He said the blower motor is bad. It seems that the whole blower assembly kit needs to be replaced, although the blower can run. Do I really need to replace the whole assembly kit?
By the way, how can I open the blower?
Thanks.0 -
Not to worry
Should be coverered under factory warranty if you registered your boiler with WM
Their not simple fans anymore, not servicable, lots of electronics in it and plays a big part of system operations>> LF is low fire, worked in my situation, but not everyones0 -
Hey Tony
You sure you know what you're talking about??? Did you take the "pro" test yet? Just wondering.0 -
Yeah, TO
I finally did pass, after I installed a new system in my own house. The couple thousand before that don't count
Inducers, blowers, pressure switches, all the same and all have 'em right ?
Ooohhh, my sarcasm isn't "nice", I should stop.....0 -
I knew you could do it
Cheerios are on me next time.0 -
Thanks
I will contact W-M. It seems that the W-M really has quality problem. My system has broken twice this year after it passed 3 years.0 -
Would you tell me how to set up at LF status?
I would like to know how to set up at the low fire status. I need to try to start the boiler up now before it is fixed. Thanks.0 -
LF
If it doesn't fire up when you reset it, it doesn't matter.0
- 133 Chimneys & Flues
- 79 Pipe Deterioration
