Brass Monkeys
Derheatmeister
Member Posts: 1,659
What is a "Brass Monkey" ?
-29F not to long ago on the Continental divide near Breckenridge..
-40F something in the "cayons" of Colorado..
If you do not plug in the trucks, good luck starting it next morning!
To quote Henry Blake,
"better keep the brass monkeys in tonight",, for the next while they`re calling sub-zero temps in my area -10F to -22F. Still not as bad as Weezbo, Darrell & Rocky, but damn that`s cold!
How about your region?
Dave0 -
let's just say...
it's always interesting to see how the heating systems work at design temperatures...Br. Jamie, osb
nope
BELOW design temps.
Going to be fun.
not0 -
well
it will give you a chance to look good if you design low enough...0 -
cold enough to freeze...
the balls off a brass monkey. thats where it comes from. do a search for "cold enough to*" on google for more info on our colorful language with its idomatic sayings....nbc0 -
brass monkey
Wasn't a brass monkey the base for what they stacked canon balls on????????0 -
Brass Monkey
Yes.
In the old Navy days, cannon balls we're stacked on a dimpled brass plate to stop them from rolling. Tis was fastened to the the deck. In extremely cold weather, the brass would contract enough to dislodge the (cannon) balls from the plate. hence the term, cold enough to freeze the balls off a brass monkey0 -
This whole time I thought it was just a song.
Beasty boys
The beasty boys that is , but what does a germerican know about this ?
Thanks to everyone to clarify this Brass Monkey Freezing Balls thing..0
