What type of insulation to use for steam pipes?
Jim Bennett
Member Posts: 607
tell you what not to use.
Saw a steam line in a commercial building newly insulated with poly foam insulation.
As soon as the steam hit it, it looked like a snake shedding it's skin!
Didn't smell very good either.
Oops!
Oops!
Most of the pipes (mains, takeoffs, etc.) in my 1-pipe steam system are still covered with the old Johns-Manville "Asbestocel," except for all of the near-boiler piping which was torn out (along with the asbestos) long ago.
I have two questions about pipe insulation for steam pipes:
1. It's not practical for me to remove all the asbestos in the basement, but some of it is crumbling, especially at the elbows. Is there something I can apply over it to contain the asbestos and maybe even gain some insulating value?
2. For my base pipes: The fiberglass insulation for heating pipes at Home Depot is the thin, crappy-looking stuff and the adhesive doesn't hold worth a damn. Plus, they don't have insulation for all the fittings, just the pipes. Is there a better product out there than what's available at the home centers? If so, where would I find it?
Thanks.
Jason White0 -
Search
Do a Wall search on "pipe insulation" and you will find all you are looking for and much much more.
on your question 1
I have -- quite successfully -- wrapped the old asbestos insulation on steam pipes, and fittings, with the plaster impregnated surgical gauze used by docs to make casts with for folks with broken bones. Stuff is pretty readily available -- I got mine from a place called Micro-Mark, but there are other resources, and cheap, and easy (if slightly messy) to use. Conforms to anything, takes the heat well, and seals the asbestos.Br. Jamie, osb
yeap....
That what I call cold water paste and cheese clothes to hold its place.0 -
If the asbestos is relatively solid an asbestos remediation contractor should be able to wrap/encapsulate it.
For insulation google for fiberglass pipe insulation contractors, or see McMaster Carr, www.mcmaster.com (though probably not cheapest source) for a sense of what's available, e.g. 1" thick x 3ft lengths, PVC fitting covers and the underwrap, etc.0
