anode rods
Jim Bennett
Member Posts: 607
Everything you wanted to know about water heaters and more....
http://www.waterheaterrescue.com/
Jim
Jim
Water heater anode rods
I know this is more of a plumbing question, but I know many of you do both plumbing & heating. In replacing anode rods in electric water heaters, do you prefer aluminum or magnesium, and why?0 -
Anode rods
Magnesium anode rods are standard in Buderus indirect tanks (I beleive most others do as well). Aluminum anode rods are commonly used when the hot water develops a "rotton egg" smell, usually caused by the interaction of the bacteria and the magnesium rod. The site list has great information.0 -
or you can check this info out
http://www.heatinghelp.com/library.cfm#Anodes
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
aluminium
is better if there is much (or any...) sulphur or sulphate in the water -- magnesium combined with the sulphate produces a weak solution of epsom salts! But magnesium will give more agressive protection, in generalBr. Jamie, osb
- 167 Indoor-Air Quality
