anode rods
Jim Bennett
Jim Bennett Member Posts: 607
Everything you wanted to know about water heaters and more....
http://www.waterheaterrescue.com/
Jim
  • Gary_15
    Gary_15 Member Posts: 22
    Water heater anode rods
    I know this is more of a plumbing question, but I know many of you do both plumbing & heating. In replacing anode rods in electric water heaters, do you prefer aluminum or magnesium, and why?
  • Joe@buderus_2
    Joe@buderus_2 Member Posts: 302
    Anode rods
    Magnesium anode rods are standard in Buderus indirect tanks (I beleive most others do as well). Aluminum anode rods are commonly used when the hot water develops a "rotton egg" smell, usually caused by the interaction of the bacteria and the magnesium rod. The site list has great information.
  • gerry gill
    gerry gill Member Posts: 3,078
    gwgillplumbingandheating.com
    Jamie Hall Member Posts: 25,707
    aluminium
    is better if there is much (or any...) sulphur or sulphate in the water -- magnesium combined with the sulphate produces a weak solution of epsom salts! But magnesium will give more agressive protection, in general
