Correct nozzle & specs for my boiler?
Patchogue Phil_28
Member Posts: 32
Thanks Alan and John.
At 140 psi with the .85 nozzle, will the effective gph be higher? I know the unit's faceplate says 1.0 gph.
Nozzle & specs for my boiler?
Looking for the correct nozzle & specs for my boiler - New Yorker S-AP model S-118. Beckett burner. I checked New Yorker's website but didn't find it.
Any online sources?
Phil, according to the 2004 Beckett OEM Spec Guide it calls for the following:
AFG Burner
F4 Burner Head
.85x80B Pref. Hago
140 PSI.
Your friend in the industry,
Alan R. Mercurio
www.oiltechtalk.com
New Yorker S-118-AP AFG head-F4 plate-3-3/8"
nozzle-.85 X 80°B(Hago) pump psi-1400 -
You're very welcome and you're also correct at 140psi a .85 will be approx. 1.01
Alan R. Mercurio
www.oiltechtalk.com
You're very welcome and you're correct at 140psi a .85gph would be approx. 1.01gph
Alan R. Mercurio
www.oiltechtalk.com
- 121 Chimneys & Flues
- 15.8K Strictly Steam
