Correct nozzle & specs for my boiler?
Thanks Alan and John.
At 140 psi with the .85 nozzle, will the effective gph be higher? I know the unit's faceplate says 1.0 gph.
  • Nozzle & specs for my boiler?
    Looking for the correct nozzle & specs for my boiler - New Yorker S-AP model S-118. Beckett burner. I checked New Yorker's website but didn't find it.
    Any online sources?
  • Phil, according to the 2004 Beckett OEM Spec Guide it calls for the following:
    AFG Burner
    F4 Burner Head
    .85x80B Pref. Hago
    140 PSI.
    Your friend in the industry,
    Alan R. Mercurio
    www.oiltechtalk.com
  • New Yorker S-118-AP AFG head-F4 plate-3-3/8"
    nozzle-.85 X 80°B(Hago) pump psi-140
  • You're very welcome and you're also correct at 140psi a .85 will be approx. 1.01
    Alan R. Mercurio
    www.oiltechtalk.com
  • You're very welcome and you're correct at 140psi a .85gph would be approx. 1.01gph
    Alan R. Mercurio
    www.oiltechtalk.com
