Buderus GB124
Joe@buderus_2
Joe@buderus_2 Member Posts: 302
The GB142 is only approved to be vented with 3" schedule 40,PVC pipe (Foam core cannot be used for the vent) . The use of stainless steel vent material is not approved. The PVC pipe can be run up to the top of the chimney and the fresh air can be taken from the room or the side wall.
  • EDMC
    EDMC Member Posts: 1
    Buderus GB124
    Is there a problem exhausting this boiler up a 30 ft chimney thru a 3 inch Stainless steel liner?
  • A.J._3
    A.J._3 Member Posts: 4
    If we take room air will that allow us to extend our vent lenth?
  • Supply House Rick
    Supply House Rick Member Posts: 1,399
    Installation Manual
    What did it say in the manual?
  • Michael Welch
    Michael Welch Member Posts: 43
    Chimney venting
    I ran both the air supply and flue up a cheminey worked out awesome here are some pics
  • Joe@buderus_2
    Vent Length
    The venting length on the GB142/24, 30 & 45 is 100 "running" feet, the model 60 is 60 feet. There is not approvals to extend the venting further if room air is used.
