burnham steam boiler problem
Tom Hopkins
Tom Hopkins Member Posts: 554
when contractor installed boiler did he skim the boiler?
  • shawn_14
    shawn_14 Member Posts: 14
    I have a client that has a new burnham independence steam boiler recently installed. He is having a problem when he manually fills with water so a 1/4 of water is showing on the sight glass he has to fill it back up in a days time. So he tried filling it 3/4 the way up the sight glass and he hears banging noises in the pipes. Any ideas ,Thank you in advance
  • JohnNY
    JohnNY Member Posts: 3,337
    Sounds like maybe...
    ...water's stacking up in some clogged returns.
    Not a boiler problem. More of a system problem.
    Have a qualified heating technician take a look at it, though, as there could be several other revealing symptoms that point to another issue.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
  • Brad White
    Brad White Member Posts: 2,399
    I agree with JohnNY
    It is not likely the boiler.
    Sort of like buying a new car because it rattles and thumps when you drive down the road. Buy a new car and it still thumps and rattles. Then you realize that those are pot holes....
    As Dan once said, "returns are guilty until proven innocent". I would check the distribution first...
    "If you do not know the answer, say, "I do not know the answer", and you will be correct!"
    -Ernie White, my Dad
  • shawn laverty
    shawn laverty Member Posts: 42
    Bump
  • shawn laverty
    What are the possible scenerios that would make this happen.
  • ed wallace
    ed wallace Member Posts: 1,612
    boiler issues
    if the return piping was not changed then it could be blocked with crud is there a draw off on the reurn lines just before the hartford loop
  • shawn_14
    The boiler was not skimmed
