burnham steam boiler problem
Tom Hopkins
Member Posts: 554
when contractor installed boiler did he skim the boiler?
I have a client that has a new burnham independence steam boiler recently installed. He is having a problem when he manually fills with water so a 1/4 of water is showing on the sight glass he has to fill it back up in a days time. So he tried filling it 3/4 the way up the sight glass and he hears banging noises in the pipes. Any ideas ,Thank you in advance0 -
Sounds like maybe...
...water's stacking up in some clogged returns.
Not a boiler problem. More of a system problem.
Have a qualified heating technician take a look at it, though, as there could be several other revealing symptoms that point to another issue.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
I agree with JohnNY
It is not likely the boiler.
Sort of like buying a new car because it rattles and thumps when you drive down the road. Buy a new car and it still thumps and rattles. Then you realize that those are pot holes....
As Dan once said, "returns are guilty until proven innocent". I would check the distribution first..."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
Bump0 -
What are the possible scenerios that would make this happen.
boiler issues
if the return piping was not changed then it could be blocked with crud is there a draw off on the reurn lines just before the hartford loop0 -
The boiler was not skimmed
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
