power inverters
Jamie Hall
Jamie Hall Member Posts: 26,845
reliable answer will be from Honeywell.
That said, in general computer/video/audio gear will not run well (if at all) from a step-type inverter (the common garden variety), but there are true sine wave inverters available (for a price!) which will run anything.
  • Jim_47
    Jim_47 Member Posts: 244
    electrical inverters
    Remote location, totally generator now, would like to add a propane furnace powered by a solar,wind,generator system. Question, does anyone know if running a honeywell 8610u or an 89xx(hot surface) will work correctly on a modified ac power? any help please.
  • jp_2
    jp_2 Member Posts: 1,935
    try it....
    my laser printer does not like the modified signal.
  • Jim_47
    Is timmie or anyone from Honeywell available to comment on
    using a 12 volt power inverter on gas components and even on 120v to 24v xfmrs ?
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,011
    exeltech...
    ...makes small true sine wave inverters. I'm running off a 600W unit now. The Alternative Energy Store http://home.altenergystore.com/ and ABS Alaskan http://www.absak.com/basic/solar-power.html and New England Solar http://www.newenglandsolar.com/ are three stores I've used that I like.
    Yours, Larry
  • Weezbo
    Weezbo Member Posts: 6,231
    Larry, my Buddy \"Battery Bob\",
    is going to like your link *~/:)
