Utica PEG-C Series Boiler - opinions?
Anyone have anything good/bad to say about a Utica PEG-C Series Boiler? I have two pipe steam.
http://www.uticaboilers.com/product_detail.asp?key=35
  • It's a basic, well-made atmospheric gas steamer
    also sold as the Columbia CEG-C series. Like all dry-base atmospheric boilers, it is a bit less efficient than a wet-base, power-burner type which can also burn oil.
    I've installed a bunch of them, if you include the proper tees they are real easy to flush out. Here's a pic of one with a drop header.
  • clammy
    clammy Member Posts: 3,255
    utica
    Utica is not a bad steamer for a dry base as steamhead has stated i have installed a few and have had no promblem but like all steam boilers mamnfactures header sizing should be followed or exceeded in size for a system that will produce dry steam ,also a s steamhead staed if piped correctly is very nice and easy to skim .Peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
