Utica PEG-C Series Boiler - opinions?
Tom Woodman
Member Posts: 15
Anyone have anything good/bad to say about a Utica PEG-C Series Boiler? I have two pipe steam.
http://www.uticaboilers.com/product_detail.asp?key=35
It's a basic, well-made atmospheric gas steamer
also sold as the Columbia CEG-C series. Like all dry-base atmospheric boilers, it is a bit less efficient than a wet-base, power-burner type which can also burn oil.
I've installed a bunch of them, if you include the proper tees they are real easy to flush out. Here's a pic of one with a drop header.
utica
Utica is not a bad steamer for a dry base as steamhead has stated i have installed a few and have had no promblem but like all steam boilers mamnfactures header sizing should be followed or exceeded in size for a system that will produce dry steam ,also a s steamhead staed if piped correctly is very nice and easy to skim .Peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 852 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
