Radiator valve
Daniel_3
Daniel_3 Member Posts: 543
Can't you just size a new nipple immediately at the last elbow? Maybe I'm missing something . . .
  • steve_29
    steve_29 Member Posts: 185
    I need some ideas on replacing a radiator with one that is 1 1/2" taller than the original.
    The HO doesn't want to repipe the riser from the basement or put blocks under the radiator.
    Do they make 1 1/4" radiator valves where the body is longer to make up the 1 1/2" difference?
    Is there an easy fix?
    thanks
  • I dislike offshore fittings but,
    if you are handcuffed for options they do make these.
    Or perhaps Christian Egli could chime-in and make you up something.
    Dave
    Dave
  • Not a fan of
    offshore fittings but they do make these.
    Or perhaps Christian Egli could make you up something.
    Dave
  • That's a \"pipe stretcher\"
    also known as an extension coupling. You should be able to find these at the better supply houses. And yes, some are still American-made.
  • steve_29
    Thanks guys!
  • steve_29
    The homeowner doesn't want me to replace the 6 foot piece from the first floor LR that goes to the second floor.
    I wish it was that easy. :-(
  • bob young
    bob young Member Posts: 2,177
    Roll it in with a set of street 45* 's
  • steve_29
    I only need to extend the pipe 1 1/2", don't you think rolling 2 45's would extend it more than 1 1/2".
    I need a 1 1/4" x 1 1/4" black bushing or something similar
