Radiator valve
Daniel_3
Member Posts: 543
Can't you just size a new nipple immediately at the last elbow? Maybe I'm missing something . . .
I need some ideas on replacing a radiator with one that is 1 1/2" taller than the original.
The HO doesn't want to repipe the riser from the basement or put blocks under the radiator.
Do they make 1 1/4" radiator valves where the body is longer to make up the 1 1/2" difference?
Is there an easy fix?
thanks0 -
I dislike offshore fittings but,
if you are handcuffed for options they do make these.
Or perhaps Christian Egli could chime-in and make you up something.
Dave0 -
Dave0 -
Not a fan of
offshore fittings but they do make these.
Or perhaps Christian Egli could make you up something.
Dave0 -
That's a \"pipe stretcher\"
also known as an extension coupling. You should be able to find these at the better supply houses. And yes, some are still American-made.
Thanks guys!0 -
The homeowner doesn't want me to replace the 6 foot piece from the first floor LR that goes to the second floor.
I wish it was that easy. :-(0 -
Roll it in with a set of street 45* 's0 -
I only need to extend the pipe 1 1/2", don't you think rolling 2 45's would extend it more than 1 1/2".
I need a 1 1/4" x 1 1/4" black bushing or something similar0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
