gas solenoid valve
Jay_23
Jay_23 Member Posts: 11
Thanks Ken
  • Jay_23
    gas solenoid valve
    When my gas fired steam heating boiler fires up, A loud buzzing noise is coming from the gas solenoid valve. It goes away after a while. System semms to be operating OK. Do I have a problem here?
  • Ken D.
    Ken D. Member Posts: 836
    Valve
    It sounds like the magnetic coil is the buzzing problem. It can last like that for a long time or the coil can fail. The coil can get excessively hot and burn up. Not an ideal situation with a flammable or explosive fuel. My policy is to never fool around with gas valves. If it is not perfect, REPLACE IT.
  • Just reverse the wires
    to the solenoid, if the buzzing stops problem solved, if not replace the valve.
