gas solenoid valve
Jay_23
Member Posts: 11
Thanks Ken
gas solenoid valve
When my gas fired steam heating boiler fires up, A loud buzzing noise is coming from the gas solenoid valve. It goes away after a while. System semms to be operating OK. Do I have a problem here?0 -
Valve
It sounds like the magnetic coil is the buzzing problem. It can last like that for a long time or the coil can fail. The coil can get excessively hot and burn up. Not an ideal situation with a flammable or explosive fuel. My policy is to never fool around with gas valves. If it is not perfect, REPLACE IT.0 -
Just reverse the wires
to the solenoid, if the buzzing stops problem solved, if not replace the valve.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
