need a starting point for a weil p468 w beckett
Steamhead (in transit)
Member Posts: 6,688
1.25x80A, 100 PSI, F6 head, 2-3/4" disk, insertion 3", shutter 10, band 0.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
i have the pleasure of doing another 1 of those calls where someone has changed all the settings--pump pressure etc.. and who knows what else through the years ---i'm going there later this evening --i cant seem to locate my Beckett application guide --can someone please post some settings -
from the Beckett bible -0 -
Hope this helps
1.25 80 A, 100psi, Shutter 10 band 0, static plate 2-3/4, F6 head,0 -
awesome --THanks guys ---- i just got off the phone with the homeowner (who is an engineer) --i had him pull the nozzle assy --just for the heck of it -----
it had a .75 90* --who knows what was done to that poor thing -----0 -
Bet
they jacked the pump pressure to 275 PSI or so....
well i found a lot of carbon the head from the angle of the nozzle ---air band set to #2 main at 0 pump at 100 -- i cant believe it was running ///the chamber was full of debris from the target wall -and soot acumulation from 20 years //// that was another fun 1 --i had a chamber kit --so i did the chamber the head was an f-6 re adjusted it all -ended up with a 110 80*
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 971 Plumbing
- 386 Solar
- 17 Recall Announcements
