Steam Boiler Leaking 4 Years Old
This boiler is leaking in several places after being installed just four years ago by others.
We had bid on replacing the previous one, but they went with someone cheaper. This is now the result.
It’s a Smith 19HE, gas fired, about 600k btus.
It’s connected to a water softener. I’m wondering if that’s the cause of the failure or could it be something else?
That softener is probably one cause. ISTR softeners exchange sodium ions for the ions that make the water hard………………
I use to service and install water softeners, including large commercial ones, and the amount of chloride that they can add to soften water is incredible sometimes.
When doctors tell heart patients not to be on softened water, you can imagine what it does to cast iron when boiled.
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
Ironman: It's very unfortunate and sad that no matter how much more information you provide, handholding you do, stellar references you have, the vast majority of people do not see the value or reason that your bid was higher and must learn the hard way. Mad Dog
2 -
The #19 is a good boiler. No way it should have failed that fast.
Maybe it just needs re-gasketing
It's worth a shot..Hopefully Ironman doesn't get outbid this time. Mad Dog
i thought the sodium replaced the calcium and other less soluble ions in the finished water and the chloride went down the drain with the calcium and other removed ions?
chloride will kill a boiler if it does end u insignificant concentration in the finished water.
it could very likely be a system that is losing a lot of water through leaks or bad traps/vents or some knuckleheading and you will have to look for that and fix it or it will happen again.
sometimes that’s a blessing
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
