How do you tell if a slow leak has damaged the wall or subfloor?
JonnyJAY
JonnyJAY Posts: 1
Hi everyone,
I've been reading about how slow leaks from supply lines, water heaters and drain connections can cause hidden damage long before any stain shows up. Most of the time the first sign is a musty smell or a soft spot in the drywall or baseboard.
I'm curious how you guys check for this during a service call. Do you use a moisture meter or a thermal camera, or do you mostly go by visual inspection and smell?
Also, when you do find damage after a repair, how do you handle it with the homeowner? Do you recommend drying the area before closing up the wall, or leave that to a separate contractor?
Would love to hear what has worked for you in the field.
Thanks!
    pecmsg Posts: 7,664
    Wait for a stain to appear.
    PC7060
  • PC7060
    PC7060 Posts: 1,985
    amazing how cynical I’ve become about generic scenario questions like this. “Wonder what LLM agent this is?”
