BTU Deficiencies in a Great Room
In 2002 I built a new house with my wife and did all of the mechanicals myself, including the radiant floor heating. I’ve discussed it here previously on the forum and have come to the definite conclusion that I am not producing enough BTUs in my great room. It has lots of glass and very high ceilings.
This time of the year when temperatures don’t dip much below 30f the system rocks. My wife and I both love the warm floors. As we are getting older and now retired neither one of us like the chill in the Great room, when the daytime temps are below 20, which happens a lot here in the winter. We spend most of our evenings in this room. The main floor is four zones and all work well but the Great room.
The house is a raised ranch approximately 1500 ft.² on the main floor with that same footprint in the completely finished walkout basement. There is three bedrooms, living room and a full bath down there. This is where our children’s bedrooms were. Since they all have their own homes and children now, we have for years not used the heating system down there, which is radiant in the concrete floor and is one zone only, with tubing in the entire area.
Here’s my question, when my system it begins to struggle, would it be a good idea to turn that zone back on, open up the basement door and allow the heat to rise up into the main floor to help offset the BTU deficiencies? I wonder how stupidly uneconomical that is in comparison to possibly just running some electric heaters in the great room when the temperature drops below 20f. Does it make sence to heat an unocupied 1500 sqft basement to add BTU's?
    Jamie Hall Posts: 28,004
    Not really. Nor, unless your electric rates are low, does it make much economic sense to run electric space heaters.
    Sounds as though you just plain need extra BTUs going into that room — which the floor is probably NOT able to provide. Got any place to hang and pipe in a panel radiator or two (or three!)? Or maybe a heat pump?
    Big Ed_4
    pecmsg Posts: 7,653
    Panel radiator
    Mini split ( I would install 2)
    Blower door test to find out why it cool/cold
  • Big Ed_4
    Big Ed_4 Posts: 3,589
    edited 10:33PM
    The basement heat loss is the living space . It can only help heating the basement during the cold weather .. I always suggested turning on the basement heat to warm the floors up stairs .. I like the addition of a panel radiator .
    mattmia2 Posts: 18,436
    could also get a hydroair coil and an air handler to blow extra heat in to that space from somewhere or a small unico/spacepack mini duct system if you don't have space for or want panel radiators although hydroair will need a higher supply temp than radiant. Does it already have ac?
