Brazing vs press vs flare etc
Curious what everyone is seeing with new equipment in regards to how you connect your linesets.
Minisplits are usually (always?) flared…..
What about normal splits, are most people still brazing their lines? Has there been any signs of a shift towards flares on such equipment?
what i see up north MI. flare for mini splits, brazing whenever its allowed. Press is still not super popular here but its catching on. it still hasn't been fully adopted here like out east. most equipment manufacturers have modified their connections to better accommodate press as it has become more and more requested, so that tells me somewhere in the US its really common for A/C
2 -
flare seems better than press in every way possible. get the hydraulic flare tool if an extra 3 minutes on the job is that important to you.
Flair 7/8, 1 1/8 or larger?
I use an Anchor brand eccentric-cone flare bar I got from United Refrigeration for most of my flares, and the Yellow Jacket bar for the big (⅞" flares) when I have to. They both work good, but flaring ⅞ & 1⅛ is a chore.
I also have a Mastercool 71475-PRC that I use for inverted & bubble flares, it also does regular flares if I wanted to drag it out. Perhaps it's from the extra steps in making a bubble flare, but the hydraulic tool isn't anywhere near as fast as the eccentric cone tool.
1 -
I started using a YJ eccentric-cone flare tool a while back and I'm still amazed how much better of a flare it makes than the typical fixed cone ones. All of my flaring headaches disappeared. Completely.
1 -
I really like mine.
I've seen guys use those spinners you chuck in a drill, but I'm unimpressed. One of the repeated selling points I've heard was "you can't mess it up". Well, the very first YouTube video I watched (I know, I know) the guy made that statement, then started one, overdrilled it, then said "oops, messed it up" under his breath, cut it off, & started over. It sticks in my memory that he said "can't mess them up" again , but that's probably not accurate. I can't see how a flat bar will make a round flare, no matter how rounded the edges are.
Flair fittings are the least reliable connection for refrigeration , maybe the temperature change on the fittings loosen over time ..
Braze is the best if done right ..But comes with the fire hazard …. Most systems come with female connections so the torch is already out .
Filter dryers and repairs propress is the way to go …
I respectfully disagree. Ive got flair fitting out there that are 20-25 years young and still holding.
Temperature changes i Assume your speaking of x-valves. Some nylog on the face and threads keep the moisture from freezing and expanding the flair nut.
It seems like flares when done correct work fantastic.
Personally…………I have more faith in my brazing than my flares.
Would a system with flares be considered semi-hermetic?
plenty of hermetic systems with flares.
those seem like they would be prone to getting chips in the system too.
I have more faith in a brazed connection over a mechanical . With the higher gas pressure I not liking the flair .. Just thinking could the copper tube and brass fitting loosen over time with change of temperatures ? I am thinking mini splits ..
Diesel engines run upwards of 30,000 psi on their fuel lines and use flares.
Gasoline direct injection engines run just under 3000 psi and use flares.
Brake lines use flares.
Refrigeration flares are pretty low pressure compared to other things out there.
brake lines use double flares on very small diameter steel or other harder line. copper flares are good for fairly high pressure too though. flares generally fail in freezing conditions where water gets in the threads and pushes the connection apart. that can be solved with pipe dope or special nuts with a relief path cut in them. flares also don't need a purge gas to prevent soot and corrosion.
Everything York make now is JUNK. But back in the day they were the Cadilliac…………except your back would go out trying to move one.
The oil company I worked for was a York dealer way back, 40s-60s I worked on some open drives and their stuff was really built.
We had tons of old York service manuals at the old office that i used to take home and read when I was trying to learn this stuff.
They wanted everything brazed or silver brazed if it was steel to copper. They insisted on it. They didn't want any service valves on the smaller stuff either, evacuate it, charge it and pinch off the access. Some things don't change, I would trust brazing over anything.
Flaring just takes practice. Tubing can get work hardened and a flare can split but all you have to do is torch it to anneal it if need be and ream the burr and you should get a good flare. I agree with @ChrisJ the newer flaring tools make a better looking flare but I didn't have many issues with the older flare tools.
I had an Imperial that would flare 5/8, 3/4. 7/8 and 1 1/8. In 46 years it hardly got used.
were luxaire and york the same company in the 50's? there were a lot of luxaire lowboy furnaces in the 50's subdivisions around where i grew up.
Luxair was bought by C A Olsen in 1939. They were bought up by Westinghouse in 1955. Borg Warner who used to own York bought Westinghouse (heating and cooling) in 1981. Looked it up.
I worked on some old Westinghouse roof top units and 1 chiller and there stuff was very good.
Funny story. I bought my house in 86' and it was a ranch. Masonry construction. It had no AC and the first summer it was awful. When the weather got hot the inside was nice and cool for 2-3 days. When it got hot it was like a brick oven and stayed hot even if the outside cooled off. Window fans did nothing and it was all casement windows, so window units weren't a thing for casements then.
Didn't have any $$$ but I bought an R-22 AHU and put it in the attic and installed the ductwork and insulated everything.
Now I needed a condenser. We had tons of old York equipment at the shop. I needed 2 1/2 tons.
I found an old unit brand new still in the crate made in 1952. It had 2 1hp compressors R-22 2 refrigeration circuits. This unit had to be installed indoors, and you were supposed to duct the condenser air in and out. It had a belt drive condenser fan and had the evaporator coil on top so it was supposed to be installed next to a warm air furnace and use the furnace fan for the evaporator.
I put the condenser in my garage "attic" that had vents. Went through the wall into the house attic with 2 suction and 2 liquid lines and mounted the coil in the return air duct of my new AHU. Funny looking for sure but it worked so so. 1hp compressor doesn't get you a ton of cooling when its air cooled (it does when water cooled) so I only had about 1.8 tons for a 2 1/2 ton load but it was better than nothing. Ran that for 3-4 years till I saved up some $$$$.
1 -
most westinghouse stuff was very good across the like 100 industries they were in before venture capitalists destroyed it.
it is very interesting that luxaire was owned by olsen. the only other time i have seen that ohio electric burner that was on my parents' luxaire was on an olsen that someone posted here
the hydraulic flaring tool is fast if you don't have to keep changing dies to make a double flare. the hydraulic tool also can get in to places where the bar and cone would be awkward.
i have had very little practice at flaring yet pretty much every flare i've made has worked out. i think i had one or 2 crack in steel or aluminum
My parents just had to replace their old York unit from around 1990. It was loud, well built, and obviously lasted a long time. I told my mom don't expect the new one to last as long. She's 76, all she wants is for it to last past her death, then it's my problem. lol
the one my parents had was from the mid 50's and it was replaced not because it failed but to switch to gas and add air conditioning in the late 80's. the luxare of whoever that actually was at that time is stull going strong minus a very slow refrigerant leak which is probably the quick connect linesets. it seems like it got a lot slower after i covered the quick connect fittings in jb weld. it went from having to charge it every 4 or 5 years to it seemed to still be filling the evaporator when it became my sister's problem.
The quick connects "Areoquip" fittings I think they called them were popular for a while.
I think they had a procedure that if they leaked you could take them apart and solder or braze them but I never tried that.
Think they are still used in automotive, trucks and busses.
I think there is a flare fitting built in to them so if you tighten them enough they seal metal to metal. the ones on the coil end seemed hard to get to and one of them had the distributor for the coil built in to it so it looked both difficult and expensive to cut them out and replace them with some other fitting and service valves.
I thought they had rubber "O" rings but I am probably wrong
i believe they have o rings to keep the refrigerant in while you are piercing the disc and tightening them but there is a metal to metal seal if you crank them down fully.
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
