Snake in the ductwork!
A small garter snake got into the house and before I could deal with it it escaped into the cold air return!
So any thoughts as how to deal with this?
Yikes!
The snake will very likely come out the opening it entered through or one of the other returns if there are other returns. Keep an eye on them and when you see the snake coming out cover the return and catch the snake. It will poop on you but that's about all you can do aside from dismantling all the returns.
1 -
Garter snakes are quite harmless — to you ad your house. To bugs and small rodents and the like, not so much. Welcome it!
Or before the fan gets him
Like a Cop once quipped about a Cat 🐈 up in a tree to Mrs Murphy:
"Don't worry...I've never seen a Cat Skeleton in a tree.....your kitty will make his way down when he's good and ready."
The snake will find his way out. Mad Dog
3 -
Update !
This critter has shown up in the basement per my wife. I have in place a sticky snake trap.
Progress!
That is really tough and cruel for the harmless snake…
If you check often enough that it doesn't die of thirst first.
Now I have to address the rampant groundhog problem! Fortunately this is outside!
