Push nipple radiator problem
Alright. So I have 2 push nipple radiators in a inhabited warehouse space that needed to be raised by 1.5". The guys doing the work used a 2x4 to lever up each end to insert a riser blocks. They noticed, and pointed out, play between a couple sections on each radiator at the top. It's enough that with finger and thumb, I can splay the sections apart about 1/64" and with a light behind the join I can see the draw bar inside. These rads were hot and leak free on Monday but clearly some of the nipples are shot and didn't like being manhandled.
Now, I'm not suggesting I would ever do what I'm about to propose but... If one was to squeeze rtv into the gaps and rig up an external draw bolt with plate steel and threaded rod.… I'm just saying. We're at about 2psi.
Hypothetically, would a kludge like that be likely to work?
Also, I'm asking for a friend.
Ok. The end caps are just ornamental plugs with no gripable features. Would you have any idea how to get them out to access the rods?
Post a pic- let's have a look at it.
If you cannot see draw rods at the top or the bottom it is probably put together with threaded nipples, common on American Radiator models.
Dave in Quad Cities, America
http://grandviewdavenport.com0 -
And if that's the case- don't mess with it.
I haven't been able to get by to take photos yet but I know the type you're referring to and this isn't it. There are nipples joining the sections across both the top and bottom. It's a push nipple unit for sure. With a light held behind the widest gaps, I can send see the draw bar inside.
With the largest gaps, I can hold a light behind the joint and clearly see the silhouette of a draw bar.
Thanks Jamie. I'm going to try squishing some rtv into the gaps between mating surfaces on the sections that show separation, draw the sections together with threaded rod clamps from the outside then wait for the rtv to cure for a day or 2 before testing. Do you think the external clamping would need to be permanent after the sealant cures? I'd be concerned about thermal expansion putting risky amounts of tension on the rods.
