NTI & HTP Boiler Recall
Looks like certain HTP boilers use the same HX
1 -
Carbon monoxide poisoning from incorrect burner door studs? It’s usually the gasket that’s the problem.
Maybe the studs break off because they were over-torqued at the factory.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Or they were out of dimensional tolerances or they were the wrong material or they weren't heat treated properly.
At least they found the problem fairly quickly its only 800 boilers.
Thanks for clarifying which model. The original article was negligent in not specifying the model but just stating the brand.
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 135 Chimneys & Flues
- 16.2K Strictly Steam
