What material pipe to use
What material pipe is correct here so it doesn’t do this again?
  • tjdumez
    tjdumez Posts: 13
    The pipes turned green from leaking?
    Mad Dog_2
    ethicalpaul Posts: 9,076
    edited April 2025
    Well it sure didn't help. A dehumidifier would also help. Anyway brass is good but those ones are probably already brass.
    It should be brass
    tjdumezMad Dog_2
    109A_5 Posts: 4,759
    I bet my boiler is a lot older. My M&M 67 LWCO and sight glass piping did not do that. However it does not leak. Brass pipe is typical in that application.
    tjdumez
  • ChrisJ
    ChrisJ Posts: 17,763
    What happens is water leaks out onto the hot surface of the pipe and evaporates. When it does it leaves minerals behind. It's turned it bluish green and increased it's size.
    Clean it up good with a wire wheel in a drill and see what you're working with and how to fix it.
    tjdumez
    hot_rod Posts: 28,704
    The blue- green is sometimes referred to as a patina. You often see it on copper roofs.
    The white color is often calcium, or lime precipitated from the water as it is heated.
    I agree with a slight seep from that union causing this. It could be much worse if it was steel pipe.
    tjdumez
  • tjdumez
    tjdumez Posts: 13
    Thanks everyone for the input! I’ll get it cleaned up and get that leak fixed asap.
