Identify this radiator valve
    edited January 2025
    honeywell unique valve
    The honeywell system book is in the library somewhere but I can't seem to find it now.
    HeatingHelp.com
  • Mark Honeywell invented the Unique Valve in the early 1900s. It gave him a way of connecting a hot-water radiator at just one side instead of two sides. The Unique valve opened with a quarter turn and used a baffle to direct the water into the radiator. The cooler water flowed by the hot water and entered the Unique valve on the other side of the baffle. In this video excerpt from his Classic Hydronics seminar, Dan Holohan teaches us about the origins of Honeywell’s Unique Valve and shows us how it works:
    And you can find the patent here:
    https://heatinghelp.com/systems-help-center/mark-c-honeywells-patent-for-the-unique-valve/
    Forum Moderator
    kcopp
  • What took you so long? Asked at 12:15 PM and no answer until 1:21M. you guys at @HeatingHelp.com are slipping. 🤣 🤣 🤣 🤣 Good job @mattmia2
    HeatingHelp.com
    The honeywell system book is out there somewhere too, maybe at archive.org .
  • Thank you all. I’m guessing that it is no longer available but can the stuffing for the stem be repacked? Has anyone tried and was it successful?
    Almost certainly can be repacked. Keep in mind that it's a quarter turn valve…
    Does it bypass as well or does it just throttle the flow to the emitter.
    Be careful and use correct tools with what you do because it likely is extremely difficult to impossible to find a replacement although there are some modern valves that can also feed from one end.
  • Where can I find the newer valves?
    To do the same thing? I don't think there are any. That valve, however, is eminently repairable.
    delcrossv
    edited February 2025
    So there is a bypass in the valve so if the system is piped such that it needs the bypass there is not direct replacement. you would have to replace it with a valve with a lance and a bypass or take the plug out of the other end of the radiator and pipe the return to the other end and a bypass. you may not need the bypass if there are separate supply and return mains. Danfoss and a couple others make a valve with a lance to feed the radiator from one end.
    by far your best option is to carefully rebuild the old valve.
    delcrossv
  • delcrossv
    delcrossv Posts: 2,204
    The only thing to go bad is the stem packing. Just repack it and call it a day.
    Long Beach Ed
  • mattmia2 -
    I'd love to know any other manufacturers than Danfoss that makes the lance type valve for one-end hot water feed. please let me know, thx.. db
  • Grallert
    Grallert Posts: 1,237
    Oventrop. They make a single entry radiator valve. Or they used to.
    https://www.oventrop.com/ae-US/productssystems/catalogue/room-climate/hydronic-balancing-at-the-radiator/one-pipe/100
  • Not common, but we even have them here in Berkeley. Truly, a wonderful, simple invention.
    Grallert
