We like Quiet. So....
So will a mod con boiler in the basement be heard? I'm not seeing sound ratings on any model. Maybe I am missing something?
  • LRCCBJ
    LRCCBJ Posts: 1,043
    It will not be heard.
    hot_rod Posts: 28,776
    But don't put it under the bedroom :)
    Exhaust noise can be annoying, so keep that in mind for termination. I'd do whatever possible to get the vent out the roof.
    Lochinvar made a model called the Cadet. It was in a 1-1/2" thick PP foam jacket. Quietest boiler I ever owned.
  • kcopp
    kcopp Posts: 4,739
    Mine is under the bedroom. The only this I usually hear is the condensate pump dumping…
  • Cyclist77
    Cyclist77 Posts: 269
    It would be under the living room. I can hear the boiler circulator when it comes on, so I'm wondering if the exhaust vent fan would be a concern? Navien is the one I am considering as there are 2-3 service companies in our area.
  • LRCCBJ
    LRCCBJ Posts: 1,043
    edited January 2025
    You'd have to have ears like Mr. Spock!
  • ratio
    ratio Posts: 4,347
    edited January 2025
    If you're looking for near-complete silence, maybe two-pipe steam with orifices? If you use an electronic LWCO,the only moving parts are the gas valve diagram and the vaporstat armature.
  • Cyclist77
    My ears aren't pointy. At least I don't think so!
  • Cyclist77
    Though my wife says I can't hear!!
  • JUGHNE
    JUGHNE Posts: 11,658
    My office is above the boiler room. I can sometimes hear one or more pumps start.
    But I can not hear the boiler at all, have to look out the window to see if it is firing.
    My wife says I can't hear either, mainly because she talks to me as she walks away or is in another room facing the corner……
    PC7060
  • LRCCBJ
    LRCCBJ Posts: 1,043
    I cannot see how you can hear any of the pumps start. I can't hear a Taco or a Grundfos if I'm standing right next to them. Are you sure you're not hearing the fan………..now that makes a bit of noise………..especially when they are not properly balanced (most of them).
  • PC7060
    PC7060 Posts: 1,982
    our dining room is over the boiler & never hear the Modcon boiler. I only hear as i walk down basement stairs.
    We could hear the 140kbtu CI monster and 1/6 hp B&G circulator anywhere on first floor. On second floor we were entertained by clanging of pipe and radiators as the 180f water hit the 68f metal.
    mattmia2 Posts: 18,437
    edited January 2025
    I hear the relays for the circulators…
    I also sometimes hear the fan and the combustion. Actually sounds like a car off in the distance.
    HVACNUT Posts: 7,811
    System 2000 EK-1F Gas or the Accel CS. IDK which one is quieter. I can't hear either of them.
    jringelszwedj
    pecmsg Posts: 7,656
    don’t move to NYC
  • Intplm.
    Intplm. Posts: 3,164
    Very quiet (if) installed properly. You can find videos on the internet that show some that are very loud due to improper installations.
  • Cyclist77
    What part of a installation causes a noisy install?
  • Intplm.
    edited January 2025
    The biggest one I have had to correct was a gas line that was too small. It made the unit make a very distinct and loud vibration sound when starting.
    hoot, whoosh, resonating are all sounds possible from lack of proper set up. Check and adjust fuel pressure, set or adjust with combustion analyzer.
    Proper venting, proper fuel line sizing, piped and adjusted to prevent excessive short cycling, good water quality. These are all part of a proper installation and commissioning.
    Intplm.
