Mepco 1E cap drive size fitting?
I'm trying to get the fairly stuck cap off a mepco 1e trap. I *could* buy the specialty trap cap wrench, but that seems wasteful. What's the size? Looks to be about 1 3/4 to me?
The largest home Depot had was the 1 1/2 water heater socket, which was a good idea but clearly too small.
    mattmia2 Posts: 18,099
    edited January 2025
    Measure it. you can get a 6 point socket from lots of places. might need a 3/4" breaker bar too. e-bay might be a good place to get one or both cheap
  • shames
    shames Posts: 14
    I used a pipe wrench. Mine is 16 inches. You can use a cheater if it’s real stuck.
    Jamie Hall Posts: 27,815
    Auto parts store
  • ariccio
    ariccio Posts: 83
    Believe it or not, I couldn't find my calipers earlier. Now, I looked again and found them in two seconds! Off to McMaster-carr...
  • ariccio
    ariccio Posts: 83
    Update: Looks like a 1 3/4 inch socket and an impact was the best choice. Popped right off.
    The best part of this, I went to show the super, and it absolutely blew his mind. Turns out he had a bucket of about 20-30 of them with caps that he hadn't been able to remove, and we then went and removed all of them in less than 10 minutes. I think I saved the building about $1k in avoided purchases 😁
