curled wire connected to gas valve
Alarry
Alarry Member Posts: 8
I have a 3 foot wire that connects from the controller to the gas valve. Due to years of overheating on the boiler jacket likely caused by the insulation peeling away, the wire insulation melted and the wire eventually broke. I replaced it with a 2 conductor power cord and routed it away from the boiler jacket so it is not exposed to high heat. My question is why is the wire connecting to the gas valve curled in this manner and is there a problem with replacing it with a straight wire. See pic. Thanks.
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,843
    No problem. The installer just curled it up to make the appearance of extra wire neat.
  • Ironman
    Ironman Member Posts: 7,926
    Electricity must be made to spiral like a football in order to travel far enough to make it into the valve.
    Bob Boan
    pecmsgEdTheHeaterManEBEBRATT-EdLong Beach Ed
    EdTheHeaterMan Member Posts: 12,491
    edited January 2025
    I believe that @Ironman might have a good point. However there is not science behind it. Pure conjecture. The real reason id that the original installed lost his job at the phone company. Back when the phones used to hang on the wall in the kitchen. He brung the wire coil trick with him when he started wiring up boilers.
    IronmanEBEBRATT-Ed
    EBEBRATT-Ed Member Posts: 20,461
    AC voltage will go around corners because it ……well alternates.
    DC is direct current it will only go in a straight line. LOL😊😊😊
    Long Beach EdIronman
    mattmia2 Member Posts: 17,409
    Strain relief. It allows it to move a little and still look neat.
    If the jacket is getting that hot you probably have rollout issues.
    bburd
  • JUGHNE
    JUGHNE Member Posts: 11,603
    Allows the same cable to be used on a variety of applications. Some need longer/shorter etc.
    Keeps the cable away from the jacket also. Gives extra wire if the ends need to be redone.
    Long Beach Ed
