Bad Pressuretrol or Bad Pressure Gauge?
skimmer
skimmer Member Posts: 176
Hits almost 8 before shutting off on pressure. Im going to check the pigtail and the nipple leading up to the gauge tomorrow.
What do you think it could be?
  • neilc
    neilc Member Posts: 3,190
    a wider view of the pigtail and gage as they connect back to the boiler , , ,
    does the gage return to 0 when the boiler is off?
    #pigtail, it's always the pigtail
    known to beat dead horses
  • skimmer
    Yes it always returns to zero
  • neilc
    still betting on the pigtail, and the port back into the boiler,
  • skimmer
    I'll find out soon enough..
    Jamie Hall Member Posts: 27,462
    Those 0 to 30 gauges…
    ethicalpaul Member Posts: 8,902
    It can be more than one. Get a new low pressure gauge, clean the pigtail, then you'll know
    Long Beach Ed
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,843
    edited January 2025
    Should be interesting. Toss a coin. Pressuretrols are notoriously inaccurate but so are cheap gauges. Your gauge is an older, used gauge, so it may be better quality than new ones. Gauges nearly never read high when they fail, unless they're not returning to zero. Pigtails always clog, but steel ones clog more often than brass ones, and yours is brass.
    My guess is the pressuretrol is wacky, but that's only a guess. It's a newer snap-switch Mexican model, not known for accuracy or precision.
    Is all h*ll breaking loose upstairs? Whistling vents, dripping water, knocking? Eight pounds can do that.
  • neilc
  • skimmer
    I plan installing a used vaporstat I got.. 0 to 4 lbs..
    the gauge was something i picked up on ebay 2 months ago, it never went that high.. but i did adjust the pressuretrol settings recently.. the differential . maybe they dont make em like they used too
    at least the vaporstat is mercury
  • skimmer
    well I checked the pigtail and it was clean. Snaked out the pressure gauge pipe. It felt clean too
    Placed the vapor stat and waiting to see. However it’s not level. I’m wonder how to fix. Maybe I can shim it? There’s some space under it
    A mercury vapourstat MUST be level. The whole calibration depends on it! Worse, it looks to me as though the curl of the pigtail is parallel to the front of the vapourstat?
    You need to redo the pigtail so the curl is perpendicular to the front of the vapourstat. That way, when the pigtail expands (it will) it doesn't throw the vapourstat off level left to right (front to back isn't critical). Then, where the pigtail threads into the boiler, you can just adjust it so that the vapourstat is level.
    Long Beach Ed
  • skimmer
    oh I see. Front to back. The pressuretrol was installed like that but it wasn’t mercury so I just followed the same orientation
  • skimmer
    Oh btw, it was the pressuretrol. this one runs and shuts down much quicker and my gauge doesnt even register.
    edited January 2025
    If after realigning the pigtail it still isn't level, you can rotate the fitting that the pigtail is connected to. You will probably have to remove the top gauge glass fitting to do so without breaking the glass, be careful. That's assuming the gauge glass fitting is connected to that brass fitting that is at the bottom of your picture. I can't tell for sure.
  • skimmer
    yes I redid it. Flipped the pigtail and it was almost level. I added a plastic shim bc it was hair off. Now it’s all good
    One difference is now I have much lower run times. More cycles though.
    It seems the old ptrol was out of wack. Running at high pressure.
    So idk what is going on now. I put in a 0-3 gauge that I thought had stopped working last year and it goes up to 0,5 before cutting out.
    The vaporstat set at 1.5 with .05 differential.
    I don’t know if it’s the gauge or the vaporstat. I have another gauge coming in the mail tomorrow.
    I’m not sure if the commas mean anything
    edited January 2025
    Watch your units. That’s a 12 oz (0.75 psi) diff. Probably fine but yeah
    commas are decimal points in Europe where your gauge was made
  • skimmer
    Oh right, I misread it. I also raised the pressure to 3 to test and gauge only hit 0.9, so i think i have a bad gauge.
    So i put the 0 to 30 back on to test and it went to 3 before cutting out.
    It's a pity it's bad. A swiss-made gauge is usually trustworthy I would think
