Urgent help needed to identify error code on Fuji indoor unit.
Hello.
I am in urgent need of identifying following flashing led´s on the Fuji indoor unit.
Operation and Timer led flashes 2 times simultaneously, and then the operation led flashes 5 times. The pattern repeats all over again.
No fan or compressor activates on the outdoor unit.
Does anyone recognize the error ?
Best regards Lars, Sweden
  • Ironman
    Ironman Member Posts: 7,938
    What are the model numbers of the indoor and outdoor units?
    If you’re not a technician, other than cleaning the filters, there’s not much you can do.
    Have you contacted the installer or service contractor?
    Bob Boan
    Lars_sweden
    pecmsg Member Posts: 7,359
    call Tech Support!
    Lars_sweden
