unusual meter readings
rick in Alaska
rick in Alaska Member Posts: 1,526
Just came across this old video I took and was wondering if anyone had any thoughts as to how this could happen? The readings are microamps, and the only thing that changed is I grabbed the meter itself, and with gloves on. I am not understanding what is going on here.
Rick
    Jamie Hall Member Posts: 27,580
    microamps?? Flaky connections!
  • rick in Alaska
    But why would touching the meter make the readings change? It would seem like a rubber jacketed meter, and my rubber gloves, that it should not interfere with anything. Some kind of a capacitance thing it seems, but not making sense.
    Rick
    EdTheHeaterMan Member Posts: 12,504
    edited December 2024
    Because of your electrifying personality?
    But you already knew that Rick
    rick in Alaska
  • ratio
    ratio Member Posts: 4,264
    One microamp is 0.000001 amps. That's a pretty small signal for a consumer-grade meter. I'd guess it's being influenced by a static charge, or it's picking up some RF energy when that big antenna grabs ahold of it.
    rick in Alaska
    So, Now Rick is an Auntenna?
    I would have guessed this nieces and nephews call him Uncle Rick. Have you had a change in pronouns since you moved to Seattle?
  • rick in Alaska
    Ok, I am confused where the aunt part of that came from, but I have only had one cup of coffee, so need some enlightenment.
    Currently in Seattle,but moved to the middle of the state, in farm country, so no pronoun changes here😁
    Rick
    mattmia2 Member Posts: 17,466
    not even rf energy, there is a lot of amplification going on there, you change the capacitance and inductance of the components and even the wiring by being close to it. i bet what you're reading is far less than the accuracy of the meter
    109A_5 Member Posts: 4,205
    What video ? The meter reading in the picture looks pretty sable to me at 6.3 microamps.
  • rick in Alaska
    Hm. Didn't realize the video didn't load. Trying to figure it out. For some reason it wants to just load it as a picture only.
    Ok, looks like I can't load a video, and i don't have a link to a place I can put it.
    So, what is happening is the reading will go from a 6.3 to a 12.4 just by me touching the meter.
    Rick
    Still just seems like a .JPEG picture to me, maybe it is my old computer.
    EBEBRATT-Ed Member Posts: 20,476
    Pic is blurry. Looks like your set on UA for micro amps but can't tell if your meter is reading an AC or DC current.
    If I had another meter as a backup I would try that to see what you get. Maybe the meter leads are tired?
