Boiler insulation refresh
guzzinerd
guzzinerd Member Posts: 461
edited December 2024 in Strictly Steam
Browsing various threads i noticed people's boilers have a layer of insulation on them. Looking under the jacket on my bryant i see none... is it missing? I don't see anything about it in the manual.
If it is missing, is it worth replacing? If so, with what?
Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
    ethicalpaul Member Posts: 8,933
    Isn't this stuff insulation?
  • guzzinerd
    On the sides there's a little, yes. I mean on the sections themselves... the naked portion in the pic
    EBEBRATT-Ed Member Posts: 20,481
    It cant hurt. I would use the foil backed fiberglass duct wrap. Or you could probably use bare fiberglass. You could get a can of spray glue and glue the fiberglass to the inside of the jacket panels (clean them off first) Just insure that you don't block any air openings that allow combustion air into the burner.
    guzzinerdGrallert
    Jamie Hall Member Posts: 27,582
    Any insulation will be on the jacket, not on the boiler sections — at least on the ones I've looked at.
    bburdguzzinerd
    mattmia2 Member Posts: 17,471
    I'd probably use high temp fiberglass just in case.
    guzzinerd
