Trouble breaking loose connection
DCDIY23
DCDIY23 Member Posts: 3
Trying to replace gas valve. Can’t break loose this fitting. Suggestions? Is it ok to use penetrating oil on gas line fittings?
  • HomerJSmith
    HomerJSmith Member Posts: 2,794
    edited November 2024
    DISCLAIMER: Although I appear intelligent, I am demonstrable dumb. Proceed at your own risk.
    It looks like a flare fitting. Loosen the top brass fitting from the brass fitting in the BI tee and then heat the BI tee and remove the brass fitting in the BI tee. Turn off any gas before this.
  • delcrossv
    delcrossv Member Posts: 2,204
    Where is copper code for a gas line?😲
    You can try penetrating oil, but I'd suggest cutting the copper, unthreading from the gas valve and replacing it all with iron pipe.
    EdTheHeaterMan Member Posts: 12,504
    It looks like you have rounded off the hex on the adaptor from copper flare to pipe tee fitting. You will need to hold that with a open end wrench that is the correct size, probably a 5/8" or 11/16" if that is 3/8" OD copper tubing. If it is 1/2" OD copper tubing the wrench will be 11/16" or 3/4" open end wrench. If you are using an adjustable wrench, that is your problem. They will slip off and round off the corners.
    If all else fails, you will need to get a thin jaw ViseGrip locking pliers to hold that fitting, then use a proper size open end wrench on the flare nut. Refrain from adjustable wrenches on brass fittings because they will slip and round off the corners of the hex fittings.
    HomerJSmithdelcrossvLarry WeingartenLRCCBJ
    You don't work on much propane gas stuff in NJ. All the LP companies use copper tubing there.
    delcrossv
  • delcrossv
    Jamie Hall Member Posts: 27,580
    As noted, don't use an adjustable wrench (Crescent or the like) on brass or copper. Use one sized to the fitting. Better yet, go and buy a special wrench made just for the purpose — it wraps around the hex further. Then you can try being a gorilla. Doesn't always work…
  • DCDIY23
    Thank you for the responses. It’s true, I used a crescent wrench, even though I knew it wasn’t the proper tool, due to my wrenches being at another location. It’s not as rounded as it looks in the photo thankfully. Nobody local sells a flare wrench that would fit. But I will go to my mothers to grab my wrenches.
    I thought the top part of the flare nut was fitted to the pipe. When I turn it, the copper pipe won’t spin with it?
    Yeah flare wrenches are a bit hard to find. As to that top nut — it should spin on the pipe quite freely once you get it even a little loose of the fitting.
    EBEBRATT-Ed Member Posts: 20,476
    Hold the flare to pipe adapter with one wrench and the flare nut with another wrench and give it hell.
    There looks like a small amount of green corrosion on top of the flare nut.
    When your done whatever, it is your doing and have the gas back on be sure to soap all the joints to make sure you have no leaks, especially with propane which is heavier than air.
    109A_5 Member Posts: 4,205
    From the Copper Tube Handbook.
    PC7060
  • PRR
    PRR Member Posts: 224
    https://copper.org/applications/plumbing/cth/
    https://www.copper.org/publications/pub_list/pdf/copper_tube_handbook.pdf —22MB PDF file
    Worth saving in my Books folder.
  • DCDIY23
    Hello again. First, I’d like to thank you all for your help. I was able to replace my gas valve, which was the problem as I hoped and not something else that would require more diagnosing. I couldn’t find a new valve since it’s an older model and Rheem took weeks to reply to my email asking what the updated replacement would be so I bought a used unit off eBay and thankfully it works and my house has heat again. I do have a couple questions though. When I was unscrewing the horizontal section of pipe that has the drip leg attached, a bunch of sediment fell out when it was upside down. Is this normal? There was a lot more than just what’s in my hand. Also, i noticed there’s some sort of grey substance leaking slightly from around the shut off valve? What is it and is it a concern? It’s not running, just that bit in the photo and nothing more. I didn’t notice if it was like that when the valve was in the open position.
    mattmia2 Member Posts: 17,466
    who did the combustion analysis after you installed the new valve?
    see if the valve is leaking, that is the grease that makes the seal in that type of valve. the pipe chips should have been removed before the piping was assembled. they likely got in the valve and caused your initial problem.
    Long Beach Ed
  • DCContrarian
    DCContrarian Member Posts: 1,515
    Here in DC the gas company runs copper tubing with a yellow plastic coating underground.
    I've never seen anything other than copper tubing used for LP.
  • worldclasshvac
    worldclasshvac Member Posts: 40
    There are lots of universal valves that cross reference OEM valves especially in older equipment. Most valves have an inlet screen and the shavings hopefully fell into the drip leg. Copper is common on propane here in NJ they usually have the yellow sleeve as mentioned earlier
