Gate vs quarter turn valve.
seized123
seized123 Member Posts: 485
At the risk of seeming totally nitpicky, would the quarter turn valve be better longevity wise than the gate valve this boiler came with? Thought I’d ask while I have an empty boiler and switching would be easy.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,675
    Exercising ANY valve is the key to longevity. Mad Dog
    hot_roddelcrossvmattmia2
  • seized123
    Good point. I’m just worried about it freezing up. Some other gate valves in this house have but I never exercised them.
  • delcrossv
    delcrossv Member Posts: 2,204
    Ball valves seem to be less prone to locking up.
    seized123
    Jamie Hall Member Posts: 27,582
    Ball valves are, I think, a little more forgiving in terms of lack of operation and water quality — and, perhaps, orientation.
    They also do one thing that gates cannot do: be set partly open. Yes, before you scream, a gate can be set partly open too — but it isn't good for it to stay that way. Either open or closed, thank you. Ball valves aren't all that good at throttling flow — they are very non-linear — but at least they can do it without damage.
    Gates are also more sensitive to water quality, and if they are used where there is significant solid material and they are oriented stem up (the usual), they can fail to close properly.
    In larger or high pressure applications, they must reflect pressure direction: when they are closed the high pressure must be such that it presses the gate against the face when closed.
    On the other hand, if maintained, they will never seize up, or at least I've never seen that happen (if the stem is not kept slightly oiled, yes but not otherwise) whereas ball valves can sometimes.
    Which makes it sound like ball valves are the way to go. But not always. In larger sizes they can be remarkably difficult to operate; gates are less sensitive to that. In very large sizes ball valves can also be very expensive, and have a longer laying length than gates. Ball valves also sometimes have trouble with the seals for the ball; gate valves depend on the accurate machining of the gate and the face and that isn't a factor.
    In general, though, for smaller valves I'd go with ball valves.
    EBEBRATT-Ed Member Posts: 20,481
    Nothing wrong with a gate valve except……..the cheap ones will leak every time.
    A cheap ball valve will outlast a cheap gate valve. And ball valves generally don't leak except the cheapies will leak around the stem.
    True, @EBEBRATT-Ed . a cheap gate valve often won't close fully off. A properly machined one won't — but that removes them from the cheap category!
    hot_rod Member Posts: 27,845
    what is the gate valve being used to shut or regulate?
  • seized123
    @hot_rod just the drain on new a boiler. Comes with a gate valve, but I have a ball valve on hand so it’d be easy to switch while the boiler is empty. Also I plan to switch out five old gate valves on zone piping to these new ball valves.
  • leonz
    leonz Member Posts: 1,864
    Keep in mind that over time a ball valve will leak through the stem. You can always repack the stem on a gate valve which is something you cannot do with a ball valve.
    Mad Dog_2Revenant
  • seized123
    @leonz I’m guessing you have to remove a gate valve to repack it, or at least have the water drained from where the valve is?
    Mad Dog_2
  • Mad Dog_2
    No..A Gate Valve is repacked via the bonnet. Mad Dog
  • Mad Dog_2
    If exercised regularly, I have seen Gate Valves that are 100 years old hold. The Jury is out on ball valve longevity vis-a-vis gate Valves, but high quality American Made Ball Valves like Apollo, Nibco, Hammond, et cetera are now over 60 yrs in operation. Mad Dog
    delcrossv
  • delcrossv
    Mechanics mate on a submarine told me when leaving a gate valve open, always back it off a little, like 1/8 turn from the stop. Keeps the valve from freezing open.
    Larry WeingartenMad Dog_2pecmsgPRR
    how often do you plan on draining the boiler?
    Maybe a rubber washer compression stop is best , like you used to see on water heaters, worse case you screw a cap on it if it drips. The stems rarely freeze on that type of valve
    mattmia2 Member Posts: 17,469
    Gate valves can to some extent lap themselves to clean the gate off. ball valves if they scale, the scale is unlikely to come off the ball. many ball valves have a packing on the stem that can be repaired.
  • seized123
    edited November 2024
    @Mad Dog_2 and others, is Watts a good brand? I bought five of these from Supplyhouse:
    https://www.supplyhouse.com/Watts-0820956-3-4-Quarter-Turn-Boiler-Drain-Drain-Cock
    to replace these in photo below (just the drains, not the shut-offs, but they’re NIBCO)
    for no better reason than they’re probably 30 years old and I heard from who knows where that ball valves are better. They’re on the zone returns and will obviously hardly ever be open. I can return the new ones, but it sounds like the jury’s out. Hey, you mentioned Nibco as American made. Didn’t know that. I try to get Apollo ball valves but sometimes just the cheaper imported ones, but if possible sometimes spring for the Made in USA’s if available.
    hot_rod
  • delcrossv
    Watts is fine.
  • leonz
    Whyt change them if they are not leaking??
    mattmia2CLamb
  • seized123
    @leonz great question. A tech with a lot of experience who came to assess my leaking boiler just threw that out there about putting in quarter turns along with other helpful advice about DIYing the replacement boiler so I just ordered them when I ordered all the other parts. Trigger happy, I guess. You’re right, they’re not leaking, and from this thread it looks like there’s no clear advantage either way and from what I understand I could repack if necessary without draining the system so why pay $88 for something I don’t need. I’ll probably return them to Supplyhouse and pay shipping and feel stupid for only about 5 minutes.
    globe valves are great for boiler drains, easy to repair with standard parts
  • seized123
    @mattmia2 I assume (without reason, actually) that what I have there are gate valves, not globe valves?
    Does the stem rise when you open and close them? I think that is a globe valve where the stem just screws straight in and the seat is at the end where the connection is. You can look in the hose connection with a light to see what type of valve it is.
    In that application i would just use an npt valve then you can easily replace it if it fails.
