TACO Outdoor Air-Sensor: Wiring Help Needed
TheSpad
TheSpad Member Posts: 3
Trying to understand wiring on the PC700-2 Boiler Reset Control. But only for the Outdoor Air-Sensor (Taco 9300-2052). The outdoor Air-Senor has only two wires - red and white. Red wire was traced to the "Out" on the PC700-2 Boiler Reset Control. White wire is traced back to the "Common" on the PC700-2 Boiler Reset Control.
The outdoor air-sensor has two screw terminals.  Both terminals are labeled the same ""S1".
How do I determine which colored wires goes to which terminal on the outdoor sensor?
Please see attached picture of the Outdoor Air-Sensor and the two terminals I am referring to.
Thanks in advance for any assistance.
    Jamie Hall Member Posts: 27,513
    It shouldn't matter. I think it's just a thermistor.
  • TheSpad
    Thank you for the reply. I thought that as well. But when I wired it up. It shows the "OPn" Trouble Code.
    See pics.
    So I assume something is wrong.
    hot_rod Member Posts: 27,704
    connect the sensor right at the control. That will eliminate bad wiring
  • Dave H_2
    Dave H_2 Member Posts: 625
    Cycle the power to the controller so that it will do a reboot and look for the sensors.
    Dave Holdorf
    Taco, Inc
