Anti-freeze testing the 'freeze point'
GW
GW Member Posts: 5,188
edited September 2024 in Gas Heating
sorry if this one has been beat to death- are you all using the fancy refractometers (I think i lost mine), or something more basic? I have been totally flushing and adding new, yet we have a new customer that says the last guy 'added in more antifreeze' every once in a while. I would need to check the ph too in this case. (I have the basic Hanna for that)
Gary Wilson
Wilson Services, Inc
Northampton, MA
gary@wilsonph.com
    Jamie Hall Member Posts: 27,581
    Can't tell you about the ways to measure antifreeze concentration — or at least sensitive ways — but there is a reason to potentially add some, or even dump and refill: you're not looking at pure glycol as your antifreeze. Most if not all also contain corrosion inhibitors and pH buffers, and those can and do get used up over time.
    GW
    pecmsg Member Posts: 7,281
    Refractameter
    https://www.amazon.com/Ethylene-Refractometer-Propylene-Glycol-60/dp/B006P0SZR4
    GW
  • GroundUp
    GroundUp Member Posts: 2,527
    Always use a refractometer to measure concentration, and strips for pH. "Freeze point" is irrelevant here- concentration is what we're after.
    GW
  • GW
    Thanks all, ok I’ll buy another one, somehow I thought they were more costly. Then, sure enough, I’ll find my other one and have two
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
    EdTheHeaterManhot_rodGGross
