Replacing old cast iron radiator with Runtal Steamview
Hello! I recently scored a set of 3 lightly used Runtal Steamview radiators for 90% off retail price. I drove all the way from Queens, NYC, to Maine to buy them. The woman I bought them from claimed that that's all she had in her small home, and she ditched the whole steam system for heat pumps. Thus the sale.
These are the radiators, for those who are not familiar with them: https://runtalnorthamerica.com/product/steamview/
My question is heat output. The woman said that the rads put out a ton of heat. I hope they do, because I love the modern look of them and the fact that they mount on the wall.
So, I want to start with replacing one cast iron radiator and see how i like it. My question is, how do I know the new rad will put out enough heat. Do I go by the BTU rating?
My assumption is, if I find the BTU rating of the cast iron rad I want to replace, I have to make sure my new rad has the same BTU or more of the one to be replaced. Do I have that right?
The cast radiator in question is 12 sections, with each section having 3 vertical tubes. Each section is 4.5"x21".
According to this calculator, it seems this rad puts out 1890 BTU. Do I have that right? https://www.expressradiant.ca/pdfs/product_classic_sizing_how_to.pdf
My Runtal puts out 5225 BTU (is is 24"x36")
Something seems off, because its hard to believe this little steel radiator can put out more heat than the cast iron big boy.
See attacehed images of the cast iron to be replaced. Thanks for any input!
  • Alternatively, if I look for BTU ratings on this link, it seems like my cast iron puts out 5040 BTU
    https://heatinghelp.com/assets/documents/American-Radiators.pdf
    Jamie Hall Posts: 27,863
    Ah… double check. Using the .pdf you linked to, I get somewhere in the vicinity of 5000 BTUh for that 12 section radiator…
  • Yeah, in the second PDF, which I think makes more sense to reference since it is American Radiators, which is what I have, I get 5040 BTU. So I should be good with my 24x36 Runtal, that puts out 5225 BTU, right? Is that how this works?
    Yup
  • bburd
    bburd Posts: 1,326
    The problem is mixing different types of radiation with different thermal mass on the same thermostat zone. If you replace all of your cast-iron radiators with Steamviews of equal Btu rating, you should be fine. If you replace only some of them, you are asking for trouble; the rooms with cast-iron will end up warmer than the rooms with Steamview. This is not a difference in energy efficiency; the cast-iron radiators require fewer, longer heating cycles while the Steamviews require the opposite.
    Bburd
    mattmia2 Posts: 18,158
    If you want it wall hung you could find salvaged wall hung cast iron radiators.
  • jumper
    jumper Posts: 2,615
    I suspect Runtal proportion of radiant to convective heat output is higher than cast iron radiator. That may compensate for less thermal mass.
  • OK well, I guess I'll install them before this winter and just see how it goes. Thanks!
  • Hey, just writing to back to say i DID install and I am VERY happy with the Runtal Steamviews. No issues, super warm and comfortable even though I am comboing this with a house that has 7 other radiators, all cast iron.
    I will say that it was difficult to install. I mounted it to the wall first, then ran the piping. But that made it pretty much impossible to get the piping to line up. So, I took the mounts off the wall, constructed a little scaffolding to support the radiator, then ran the pipes and added the mounts after the pipes were all connected and checked for leaks. Withe the rad on the scaffolding, this allowed me to move the unit around to get the pipes hooked up successfully. Hoping to replace more of my cast iron units in the future using this method.
  • Intplm.
    Intplm. Posts: 3,152
    @sjenkins318 I installed some of these last fall and had some trouble with the female treads being a little to large. Im curious, did you have the same problem?
  • On the Runtal? 1" NPT. No issues there…
  • Intplm.
    Good to hear. The brand new ones fresh out of the box didn't like the 1/8 or 1/4 inch threads used as plugs on the units I had. It took some doing getting that corrected.
  • Mad Dog_2
    Mad Dog_2 Posts: 8,744
    Steamview rads are neat but it's Nolo contendre as far as heat output. Mad Dog
