odd flushing toilet
GW
GW Posts: 5,253
Never thought i would get jammed on a toilet- but here I am.
I have an apartment with a modern 1.6 gal, 17" tall, elongated toilet, American Standard Cadet Pro 3 i think it is.
First flush is super lame, no flush, bowl just fills a bit. Then, the Tank fills and the second flush is almost good as normal.
I ran an auger, but nothing
Something in the rim?
Gary Wilson
Wilson Services, Inc
Northampton, MA
gary@wilsonph.com
«1
    Jamie Hall Posts: 27,818
    Beats me. But when you find out what it was, let us know — I have one of those, too.
  • DCContrarian
    DCContrarian Posts: 1,572
    Is the water level in the bowl and the tank the same for both flushes?
    How about a third flush? What's it like?
    I'm thinking there's a leak, but not enough to get the valve to open. So there's less water in the tank when it's been sitting for a while. When it's freshly filled the tank is full and you get more water.
    ttekushan_3
  • GW
    GW Posts: 5,253
    I didn't pay attention to water level, good point. But yes, no 'tank filling' happening.
    3rd flush is like the 2nd flush
    I'll ask the tenant to pop the lid and take a look. (he seems able minded)
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
    mattmia2 Posts: 18,101
    Pressure in the building could be pushing some of the water out of the bowl over time too.
    What if you hold the lever so it empties the tank on the first flush? Not quite sure what that tells you but it is another data point.
    The flapper or other flush mechanism in low flush volume toilets is designed to drop back in to the seat long before the tank is empty usually by when the air leaves the bulb in the bottom but this is definitely something to think about. It is going to make the water level dropping an inch or 2 because the flush valve isn't holding a lot more noticeable.
  • GW
    GW Posts: 5,253
    right, holding the handle does not change anything. It's an odd one. I've been pushing the flush handle for decades, never been stumped till now
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • neilc
    neilc Posts: 3,204
    the little pilot jet hole at the bottom of the bowl where it transitions to the throat of the trap, down there in the dirty,
    mine got clogged heading back up to the rim, when yellow mellows it can crust that small pilot channel,
    I ran a snake up there, actually some 3/8 vinyl tube, and broke thru,
    been flushing like a champ since,
    might be worth checking.
    known to beat dead horses
    kcoppPC7060GW
    You could dump a bunch of citric acid in the bowl and let it soak a while.
    PC7060GW
    could be something either in the passages in the bowl or in the drain that is floating around
    GW
  • neilc
    neilc Posts: 3,204
    I had read to pour the acid or CLR down that center refill tube to clear the rim jets, and that syphon pilot passage,
    sometimes my hands get dirty
    GWPRRhot_rod
    edited June 2024
    If the toilet discharge pathway gets reduced in size by urine salts, you won't get the siphon action you need for a proper flush. Put a glove on and reach down in there and feel the "G" spot and if there's a buildup of deposits, chip it away with a bent spoon or other tool.
    I've used Ed Fred Toilet Bowl Cleaner with good results. Remove all the water in the bowl, pour the entire bottle of Ed Fred in and let it sit overnight. I only have the one toilet in my house, so I had to go in the garden in the middle of the night when I did it. Flush in the morning and scrub that channel with a brush. A second application may be necessary.
    GW
  • DCContrarian
    I have limited patience for working with toilets. A new Kohler is less than 200 bucks. The hardest part about replacement is carrying the new one in and the old one out.
    GW
    assuming the flooring goes underneath it
  • I'd be tempted to either;
    just change the flush flapper on speculation, or
    flush toilet let it refill and then turn the water off for the night, then recheck water level in the am
  • Intplm.
    Intplm. Posts: 3,151
    Fill a bucket with water and dump it down the bowl. If it flushes it's probably not the bowl but the tank. Be sure to check that small ping-pong-sized hole in the bowl for an obstruction.
    Does it have a cylindrical flush valve or a flapper? I'm guessing it's a flapper type with a float on the chain. Either the chain or the float, or both need adjustment. And try adjusting the ball cock to create a high water level.
    If all else fails change the toilet to a Kohler toilet with a cylinder-type flush valve and be done with it. The low-flush toilets can be a bit of a pain with this type of thing.
    mattmia2GWPC7060
    The flush handle could have rotated in the china changing how far it lifts the flapper too.
  • GW
    GW Posts: 5,253
    yes, all of my units have properly floored and installed flanges-toilets !
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • GW
    GW Posts: 5,253
    edited June 2024
    Ok thanks, is kohler the new king? I am out of touch with what's best these days
    What model Kohler? Always happy to spend dough on whats best
    Yes, its a big flapper
    Good idea with bucket
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • dko
    dko Posts: 669
    Will never go wrong with a Toto Drake series tank/bowl
  • Intplm.
    Kohler is a very good toilet. They have some very good price points too. Are they "king" not sure, but I am sure that they are very reliable and install quite well. If you do get one, avoid the flapper-type flush valve and get a cylinder-type flush valve. They align very nicely avoiding mechanical problems. And they are not too hard on the wallet either.
  • Intplm.
    Model numbers don't come to mind. The big box hardware stores have them in large single boxes that come with pretty much everything you need.
  • GW
    GW Posts: 5,253
    cool, I remember the Cylinder style from the 1980's.
    I forgot the brand at this moment, not one of the majors.
    I always thought they were goofy. But I see that times have changed.
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • GW
    GW Posts: 5,253
    We have Toto at our shop-office. They are great, but not super nice looking and the bowl almost touches the baseboard trim, which i think is odd.
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
    Steamhead Posts: 18,891
    We love the Gerber Viper we have at the office. Haven't been able to stop it up yet- and we've tried 😫
    Semi-retired
    GWSuperTech
  • PC7060
    PC7060 Posts: 1,957
    Cimaron is my preferred Kohler terlet. Newest series have a nice edge flow channel to really scour the bowl.
    GWIntplm.
    GWPC7060
  • GW
    GW Posts: 5,253
    yes that’s the Mansfield
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • Intplm.
    Yes! Very nice lol. But let us be sure not to mistake the use of one for the other. Or has that already happened?
  • ChrisJ
    ChrisJ Posts: 17,675
    edited June 2024
    @GW If buying a Kohler I'd pull the lid to make sure it uses their cylinder style flush valve which I think all of their better bowls use. Maybe all of them do now, I don't know.
    It seems to take far less effort than a large flapper or even a older normal flapper for that matter.
    I just installed a Memoirs Stately 1.6g a few months ago and have absolutely no complaints about it.
    GW
  • Pumpguy
    Pumpguy Posts: 810
    Would anyone know if that Aqua Piston flush valve can be used to replace the common flapper valve?
    If yes, is this true for all brands?
  • You would have to know the diameter of the hole in the tank and the diameter of the receiving hole on the bowl. If they match and the toilet bowl was designed for the same number of gallons per flush it should work. An important thing to consider with this setup is that to make sure the tank is plumb and level. If the Piston is riding up and down at an angle it has trouble consistently seating.
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
  • GW
    GW Posts: 5,253
    It doesn't seem extremely impressive, the flush. It's peculiar- they don't show the entire flush cycle, they kind of 'zoom in'.
    https://www.google.com/search?client=firefox-b-1-d&q=kohler+cimarron+toilet#fpstate=ive&vld=cid:6795aaac,vid:l-gmtoM58VE,st:37
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • dko
    dko Posts: 669
    It's not just the flush valve mechanism, but the design of the bowl. The drake style where it swirls all around helps clean very well too.
    PC7060
    This type doesn't siphon the trap. I saw them in Japan when I was there- not very impressive. Toto does make one with the same rim jet setup where the trap does siphon- I'd use that one.
    Semi-retired
  • ChrisJ
    This is my 1.6g Kohler Memoirs Stately flushing.
    Its bowl rinse is very good and it doesn't clog.
    https://youtube.com/shorts/OJgppe4oXkk?si=3wg98_R-lkSNJ2uI
  • PC7060
    PC7060 Posts: 1,957
    edited June 2024
    it moves the 💩 with zero clogs, what more we could ask. 😂
    PS: that is also the older version with rim type flush through lots of holes. Newer one jets all water from rights side in channel and scrub the bowl with stronger swirl.
    funny they all seem to make the gulping sound though.
  • ChrisJ
    A good bowl rinse
    If it's got that and no clogs then it's perfect.
    PC7060
    EBEBRATT-Ed Posts: 21,026
    I have 2 Kohlers 1.6 gph about 15 years old. One is round the other elongated. They both flush good but the round one is better.
    I changed one in my nephews rental property. I put in an American Standard cheap HD toilet. Forgot the model 1.25 gph and it flushed great.
    PC7060
    One curious downside to the modern low flow toilet (not knocking them, Cedric's home has a couple). One of the outbuildings (a guest cottage0 has a very long very flat (about 300 feet, 5 foot drop) sewer line (4 inch) leading to the septic system. I tried a low flow toilet on that line…. and the line clogged. Not enough flow per flush to convey the solids to the tank. (Fortunately I was able to flush it out) Reest the old WC…
    PC7060PRRdelcrossv
  • ChrisJ
    Cast iron?
    Curious if replacing it with 3" PVC would fix the issue.
    Your pipe is less than 1/4" per foot but more than 1/8 so it still passes modern code.
