Connecting Steam Radiator
What is needed when connecting the radiators? Pipe dope, wicking thread…? Thanks
Nothing, just clean mating surfaces on the radiator and valve half of that union
Clean them No sandpaper. No abrasives. Just clean (you can use the scrubby side of a nylon dish sponge… but nothing else).
Then make sure that the radiator is perfectly lined up with the valve. When you go to put it together — hand tight on that union nut, and perhaps half a turn more. No more than that.
That connection is called a Ground Joint Union
A ground joint union comprises of an angle that is cut into the union to make the two sections meet. It increases the surface area at the joint allowing seating properly. It is a metal to metal connection that makes an airtight seal. You must have the matching pieces to make that connection. The connection has a precision machined mating surface. No sealant necessary.
If that radiator is a replacement with a spud in the radiator that does not match the valve part of the union coming out of the floor, then you need to purchase a complete new valve with matching spud.
1
- 125 Chimneys & Flues
- 169 Indoor-Air Quality
